Hi EK,
You can't get a 50% duty cycle pulse at 25KHz with the Step/Dir Generators because that would require a 20us pulse every 40us. The max pulse size for the Step/Dir Generator is ~4us (setting of 63 at 16.67MHz).
Your code example below is setting a value larger than 63 as the pulse length.
Consider using a PWM to generate the signal. You won't be able to generate exactly 25 KHz but I can't imagine that the frequency would be critical for a charge pump.
Message: 608 |
Date: 8/25/2010 |
Subject: Re: Need help with a frequency generator. |
That might explain my problem. But if a stay with the Step/Dir generator and use 4us pulse, how would I set it up for approx 12.5 khz frequency?
EK
> Hi EK,
> charge pump.
> From: ekonradsson <erlendur.konradsson@...>
> Sent: Tue, August 24, 2010 5:04:52 PM
> Subject: [DynoMotion] Need help with a frequency generator.
> I posted a few weeks ago about how to use the PWM generator to generate a 25Khz
> signal. I managed through trial and error to approximate the signal using the
> step and direction channels but never figured out exactly how it works.
> It turns out I need a 12.5 Khz signal at 50% duty cycle, not the 25 Khz but cant
> figure out how to calculate it properly. Can anyone help?
> The code below is based on an example program that came with the controller.
> void StartChargePump()
> int Frequency;
> double DutyCycle, Period;
> int Pulse=200; // 1000 Gives approx, 5Khz signal. 200 gives approx 25 khz signal
> FPGA(STEP_PULSE_LENGTH_ADD) = Pulse;
> DutyCycle= 0.2978; // Note Duty Cycle can't be zero (useful range 0.02 - 0.98)
> Period = Pulse/DutyCycle;
> Frequency = (int)(0x7FFFFF/Period);
> FPGA(STEP_RATE_ADD+0) = Frequency; // put 23 bit frequency
> FPGA(STEP_RATE_ADD+1) = Frequency>>8;
> FPGA(STEP_RATE_ADD+2) = Frequency>>16;
> FPGA(STEP_RATE_ADD+3) = 0x88 + SCHPChanel; // combine enable, Drive High and low
> mode, channel
> Thanks
> EK
Message: 609 |
Date: 8/25/2010 |
Hi EK,
Basically output a 23 bit number that ranges from 0 to 0x7FFFFF that linearly scales from 0 Hz to 16.67 Mhz
so for example compute the period you want in terms of 16.67MHz clocks.
Period = 16.67MHz/12.5KHz = 1333.6 clocks
then compute and set the frequency
FPGA(STEP_RATE_ADD+0) = Frequency; // put 23 bit frequency FPGA(STEP_RATE_ADD+1) = Frequency>>8; FPGA(STEP_RATE_ADD+2) = Frequency>>16; FPGA(STEP_RATE_ADD+3) = 0x88 + SCHPChanel; // combine enable, Drive High and low mode, channel
Message: 611 |
Date: 8/26/2010 |
Thank for the explanation. Much appreciated. Lets just hope the 4us pulse is long enough.
EK
> Hi EK,
> mode, channel
> Sent: Wed, August 25, 2010 6:34:03 PM
> Subject: [DynoMotion] Re: Need help with a frequency generator.
> Thanks
> EK
> > Hi EK,
> > because that would require a 20us pulse every 40us.ÃÂ The max pulse size for
> >the
> > Consider using a PWM to generate the signal.ÃÂ You won't be able to generate
> > charge pump.
> > From: ekonradsson <erlendur.konradsson@>
> > ÃÂ
> >cant
> > int Frequency;
> >signal
> >low
> > mode, channel
> > Thanks
> > EK
